Re: getting a seized metrakit overbored
geners b /
the best thing to do it is look into your cylinder and check to see if there's any deep scratches...depending on the depth of the scratches, you need to determine the size of the piston you will need. the metra 65ccs come in 43.5mm(stock size), 43.7, 43.9, 44.1, and 44.3mm oversize pistons....when overboring you want to make sure that your not left with any scratches... as it defeats the purpose, as it may cause blowby
greg sorry but that's not the way to do it, as stated above the pistons only come in certain sizes...purchase the piston first, bring the piston and cylinder to the machine shop...they're gonna measure the piston size with a caliped....then they're gonna bore the cylinder to the size of the piston with a certain tolerance for piston expansion etc....you might wanna ask benji or 1977 if they have oversize pistons.... or order from metrakit themselves
  getting a seized metrakit overboredTopic by: j j 05/05/08 01:48AM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/05/08 03:52AM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 04:24AM
  getting a seized metrakit overboredRe: Brennan O. Brennan O. 05/05/08 10:26AM
  Re: getting a seized metrakit overboredRe: Los Los 05/05/08 10:49AM
  Re: getting a seized metrakit overboredRe: Silverfox Sullivan Silverfox Sullivan 05/05/08 02:47PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 02:50PM
  Re: getting a seized metrakit overboredRe: j j 05/05/08 03:56PM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 04:55PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 05:40PM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/05/08 06:06PM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 08:39PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 09:46PM
  Re: getting a seized metrakit overboredRe: Chris Paz Chris Paz 05/05/08 10:02PM
  Re: getting a seized metrakit overboredRe: j j 05/05/08 10:11PM
  Re: getting a seized metrakit overboredRe: Brennan O. Brennan O. 05/05/08 10:17PM
  Re: getting a seized metrakit overboredRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/06/08 02:14AM
  Re: getting a seized metrakit overboredRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/06/08 02:30AM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/06/08 03:01AM
  Re: getting a seized metrakit overboredRe: Speedbird Speedbird 05/06/08 06:03AM
  Re: getting a seized metrakit overboredRe: j j 05/06/08 06:22AM
