What could I do if i didn't put a speed kit on. Bigger Carb, HP pipe, change gears? If you have done this let me know what you matched up to get more from your puch. I have a 1 and 2 speed Maxi.
tj
tj
High compression head, biturbo, 15mm carb and intake, high flow filter, and 16 x 45 got me to 32 mph on my 1 HP maxi. Had to mess with the cylinder though. It would be easier to just buy a 1.5 or 2 hp cylinder.
low compression head, low torque non restricted cylinder (ported), trim piston to line on inside, larger carb, gearing, Some type of pipe for top end.
You don't want a lot of compression for high speed. It makes the engine work harder and therefore go slower. If you want torque then go with the HC head and a ported high torque cylinder (they will be a touch slower).
I have two 2hp Maxis ones a 1 speed and the other is a 2 speed. I also don't have much knowledge for the engine work. Mostly looking for bolt on ideas. I am looking to get more top end, right know I go about 30MPH.
compression = power
combustion engine basics.
just because its harder for you to turn over by hand doesnt mean its harder for the motor.
