Another Problem, Another Post
craiiiiiig /
Hi everyone,
Well more problems with my Magnum (e50, Metra kit, 19mm Dellorto)...
The bike will idle when it's up on the kickstand but not when it's on the ground. The bike will also run if you can get it up to speed (and runs great) but will die as soon as you come to a stop. In order for the bike to idle on the stand the idle speed screw needs to be turned in all the way, the air mixture screw does not seem to affect greatly but does make a difference. I put a bigger idle jet in there yesterday and it did make it idle better but still won't run off the stand. Is there still an air leak? I have sprayed that thing down with so much carb cleaner to no avail. I did find a leak between the intake an cylinder but I fixed that one and noticed a big change. This problem of not idleing off the stand actually started after I fixed that problem.
I'm pulling my hair out over here. I can't thank you guys enough for all the help I've gotten so far, sorry to keep posting so much, the Dellorto is a whole new world of pain.
  Another Problem, Another PostTopic by: craiiiiiig craiiiiiig 05/04/08 02:35PM
  Re: Another Problem, Another PostRe: Silverfox Sullivan Silverfox Sullivan 05/04/08 02:44PM
  Re: Another Problem, Another PostRe: Flagrant - Flagrant - 05/04/08 02:51PM
  Re: Another Problem, Another PostRe: Chris P Chris P 05/04/08 03:21PM
  Re: Another Problem, Another PostRe: Flagrant - Flagrant - 05/04/08 02:53PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 02:59PM
  Re: Another Problem, Another PostRe: Chris P Chris P 05/04/08 03:25PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 03:01PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 03:03PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 03:22PM
  Re: Another Problem, Another PostRe: Graham Motzing Graham Motzing 05/04/08 04:20PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 04:39PM
  Another Problem, Another PostRe: Brennan O. Brennan O. 05/04/08 04:46PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 05:10PM
  Re: Another Problem, Another PostRe: Brennan O. Brennan O. 05/04/08 05:12PM
  Re: Another Problem, Another PostRe: geners b geners b 05/04/08 05:13PM
  Re: Another Problem, Another PostRe: craiiiiiig craiiiiiig 05/04/08 08:38PM
  Re: Another Problem, Another PostRe: geners b geners b 05/04/08 09:52PM
  Re: Another Problem, Another PostRe: geners b geners b 05/04/08 10:00PM
