would i benefit from jetting it along with the pipe?
what jet would i use?
and as for air box mods does that just consist with drillin extra holes in it on the filter side?
i have a tomos sprint with a a35 btw with stock carb
Im not entirely sure that you have to rejet with an exhaust. But, everyone seems to recommend it. I think it might be because expansion exhausts push unburnt mixture which would otherwise exit out the exhaust back into the motor. So the extra fuel gets pushed back in resulting in more power, and making better use of the expansion chamber. Im no expert but as a quick answer Id probably go up 2 sizes.
As for air box mods, just figure out where the restriction is, and de-restrict it. You could even run no air box, but I dont recommend running no air filter. If you de-restrict your air box, then you pretty much have to upjet or you will be running leaner, you have to be careful not to run too lean or your motor may not receive proper lubrication. Id say another 2 sizes for a simple de-restriction.
So for a quick answer from a person without much experience in this, Id say go up 4 sizes if you do both.
and that size would be? because i know there are like #102 and stuff so what would i need. if i can i might try and get a different carb that does away with the air box. do you recomend poring a little bit more oil in as well
I dont know much about Tomos, so I dont know what size jet they come with stock. But if you take the jet out I think it should be labeled. Someone here probably knows though.
Generally carbs come with an air box as standard.
No putting more oil in is probably not a good idea.
alrighty, thank you but before i get the jet should i put more oil in it? and if i am going 32 ish now what can i expect with the pipe and air box (just an estimate)?
The jet that comes in it is a #53. With the biturbo I ran a #56 jet and that was perfect for me. Should be in the ballpark. I just ran it with the stock filter. Your speedo says 32mph. That is not accurate. But your speedo is going to say low fortys with the biturbo. I'm not saying you'll be going that fast. But the speedometer will be reading that high. Mine was reading about 45mph when I had mine.
why is it not accurate?
