70cc Speed Kit ( 1 Speed or 2 Speed)
I have a 78 Maxi 1 speed and 79 Maxi II 2 speed. I want to put a 70cc speed kit on 1 of them. Which one motor is better to do it with, which motor will last longer? I really like the 2 speed but not sure if it is a good motor to do it with. Any advice you can provide would be great.
TJ
Re: 70cc Speed Kit ( 1 Speed or 2 Speed)
Generally speaking, most people prefer the 1 speed (E50) to kit due to its simplicity/availablitly of parts/reliability.
Many people have kitted ZA50 (2 speed) but due to the extra power, it tends to be less reliable. It's definitely do-able but for a daily rider....i would go with the 1 speed and just re-gear according to your needs.
west seattle has kitted both 1 and 2 speeds, and the 1 speed is the only way to go!
If I was going to go with a 1 speed with a 70cc kit what gear would be best? I live in NH so we have some hills but it would be mostlly on a somewhat flat area with a slight incline. I was looking at a speed kit from the Moped Junk Yard comes with engine, carb, HP Pipe. but nothing about HP air box or gears?
TJ
Who could I contact to get info regarding what to get. I want to do it right the first time.
TJ
You will be ok with 16X45 gears and dont bother with a kit if your not going to match the ports and good luck with it.
