homeot p4 on maxi
does the homeot p4 pipe bolt right up to the maxi or do you have to drill out the hole for the exhaust bracket? mine is like a 1/4" off and can't seem to force it.
Re: homeot p4 on maxi
Make a little bracket extension and use 2 bolts.
small s shaped extension
and the extension would be better than just drilling out the hole on the exhaust more?
Well, you can also drill out the hole on the exhaust if you like. Just make sure that it still supports the exhaust after that. Homoets are notorious for eating exhaust-studs.
washers washers washers.
