need a little jet advice
i'm going to put a few things on my stock one-speed puch maxi, and need some help with jetting. i will be running a 15mm bing carb, 15mm intake, high flow air filter and a stock exhaust right now. i think the jet range should be around 68-72ish? but i'm not really sure... any help would be appreciated! oh, and i'm on the west coast in the pacific northwest (i think altitude affects things too?) thanks!
Re: need a little jet advice
Iron Hayden /
please? and thank you!
Yep, that sounds about right. maybe buy a couple sizes higher too.
Iron Hayden /
thanks a bunch, Brennan!
68-72 sounds about right to me
Iron Hayden /
cool. i will start around that range. the 15mm bing comes with a #82 jet, so i wasn't sure if i should go higher or lower. thanks!
I have a similar setup coming in the mail... But I got an exhaust too...
1 speed
new 15mm bing
new technigas next exhaust
new 15mm intake
new performance air filter
How much higher should I go because of the exhaust?
I live in michigan if elevation is part of the issue...
Iron Hayden /
nice set up. i haven't picked an exhaust yet... let me know how that set up works out. you'll probably be up and running before i will. good luck.
Well I was just wondering what jets I should use in this setup.... I need a range to tune with...
