Hydroform Bues
ok so I'm trying to get better at Hydroforming, and I have found that in order to be successful you need absoFUCKNLUTE PERFECT0N! ugh, anyone have any hints? I thing I'm getting better though:
N0 sharp turns
N0 thick welds
and pre-bend a bit
Re: Hydroform Bues
i fucking love you hippy.
Re: Hydroform Bues
Hey if you used compressed air it would absorb less heat. But I am not familiar with the concept
Re: Hydroform Bues
The water is for safety
Re: Hydroform Bues
DUDE YOU ROCK keep it up...
Re: Hydroform Bues
Your a genius, keep at it!
Re: Hydroform Bues
what if you make a mold sorta? like hydroform it inside a premade shape?. You could like take a pipe, cut it in half and use it. It would be a tiny bit smaller though.
Re: Hydroform Bues
yeah, you should look into making a negative mold for it.
Re: Hydroform Bues
that's the right word! a negative mold. of course, i have no idea how. make it out of quick-crete?
Re: Hydroform Bues
maybe pressurize the pipe and heat the areas that are kinked/dented with a torch.
Re: Hydroform Bues
hippy, you rock what PSI are you using? just standard street pressure? word! keep fighting the good fight
Re: Hydroform Bues
Bruce Edwards /
There are many ways to make a negative mold. An easy way is to take a piece of MDF or plywood and cut out the shape of the object in the center. Next cut progressively smaller "layers" of the object and glue/screw them to the one cut prior. When done you can fill the inside "steps" with body filler and give it a final sanding.
Do the same for the other half and clamp them together when forming your piece.
Re: Hydroform Bues
How are you bending the sides? I think thats where your kinks are coming from. The bent sides aren't quite straight, so once you weld it, the sides aren't straight. Maybe you need more pressure?
Re: Hydroform Bues
everthing i've read about hydroforming pipes suggests that you should put it in some kind of clamp to stop the main section of the expansion chamber expanding before the rest...this might help you?
Re: Hydroform Bues
Yeah, I think in order to do this absolutely right, I'm gonna need:
A) Higher Pressure
B) a way to make perfect cuts and bends on the pipe(I'm using a band saw and vice to bend, I just think I may need to take my time)
C) the Negative mold sounds good! I'll try that
D) and I'll try that clamp idea too!
Thanks Y'all!
Re: Hydroform Bues
Maybe you should roll it with an english wheel instead? it'l take more time, but you wont have kinks. then again, im not if you can roll something that tight with an english wheel. that tight of a curve i mean.
Re: Hydroform Bues
check your MA email
Re: Hydroform Bues
If I had a wheel I would...
