Re: Peugeot Carb & pipe
Eric /
Ive actually researched a whole lot on this carb and done everything I could find to make it work, the big problem I have is at idle no matter what I do it just wont run right, I have resealed the intake, cleaned and soaked the carb, redrilled the main jet to the proper size because it was gunked shut, and then I found a local shop that showed me a way to unclog the idle holes and that still didnt help, another strange thing is that the Idle is stuck really high and I cant get it to come down.
I'm kinda new to mopeds but well versed in motor cycles and cars so I know enough about carbs to get by, to my understanding the screw in the side is used for the low speed mixture but if I unscrew that enough to drop the idle the bike won't move at all and tops out at like ten miles per hour so I think I am giving up on this carb.
any Idea where I can get a dellorto, also any pipe suggestions?
