anybody run them? are they faster than 17-2 1/4
my friend has a maxi with the 2" with an identical setup to my newport with the 2 1/4". He usually got 2 -3 mph faster, but he was lighter than me.
hahahahaha
all of the cuperteens are going to be running 2's. Hella FAAAAAAAAAAAAAAAAAAASSSSSSSSSSSSTTTTTT
QK has 2" IRC's in stock.
gasp, the secret is out!
not really!
I always run 2"s or 2.25 if thats all i can get anything more and ur compensating for something
lolz
I tried 2" and I was scared. I guess I'm not fit to ride how elliot does. I put an old 2" on the back and it was super sketchy! Up front its fine, but at least 2.25 in the rear.
I still like my 2.75" tires despite the weight. So stable and grippy.
the tread pattern has more to do with grip than the width, but still.
i'd run 2"ers if i could find ones i liked
i think the profile really makes the biggest difference in the gripping. when i run a small round tire like that, i usually air way up, to like 40 psi. the combination of the two makes for ok-ish handling, but helps top speed. every little bit helps.
i love the way 2.75 grip the road and suck up the bumps but i loose power going up hills and takes longer to get going fast.i guess i need to wait for the 80cc kit.
i like how fast the skinny tires go but they really really suck on these ohio gravel back roads and trail rideing
right now im running a comprimise between speed/handleing and comfort i have 16-2 1/4 front and 17-2.50 rear this combo handles very good for me .it is very stable and extremly responsive.
