de-celeration question- puch
perhaps the title is a little off- but my question is about the performance of my bike- so heres the scoop
e50
polini port matched
4 pedal reedvalve
20 phbg
-9needle
-98mainjet
-48or52 ideal screw
estoril exhaust
and CDI
so heres the low down- ill be riding and everything is all good- i get to higher speeds
id say around 40!? give or take 5 mph and then ill let off the throttle if there is a red light approaching or whatever but the bike will still pull and feel like the throttle is engaged. it can be kinda scary at times. but by the time i get down to like 10-15 mph the pulling will go away. but it takes some serious braking power.
any thoughts? suggestions?
Re: de-celeration question- puch
rpms not dropping when you let go of the throttle is a sign of running lean. I'd guess you need to put in a bigger main jet. like 100+.
yep, you need to upjet. Mine did that with an estoril back in the winter. Runs much better with the N8P(but still issues, see my thread)
