Gear reduction/Puch
so I know I've seen this before but I've been searching forever and can't find it:
if you have_____RPM than you go_____MPH with a __front sprocket and a __rear sprocket with 17inch rear wheel or ___radius.
does anyone remember this post? and what the reduction is from the crank to front sprocket?
to answer the question how fast is 12000 RPM with 15x36 gearing?
Re: Gear reduction/Puch
Jason Luther /
do you have a V8 or something to reach 12, 000 rpm with that gearing?
A 50cc would reach 12k much easier than a V8. You'll probably have to take into consideration the gearboxes internal gearing also.
holy balls... your gila is turning 12k?
Start with what you know..
lets say the diameter of your wheel equals 22 inches total.
thats a circumference of 69.08 inches or 5.76 feet
one mile is 5280 feet
you your wheel needs to turn 916 times to travel one mile
or 916rpm would be one mile a minute or 60miles per hour
multiply that by your gear ratio of 2.4 and you get 2200rpm at your output shaft.
I don't know the internal gear reduction of puch so figure that out and multiply 2200 by that and you get crank RPMs @ 60mph. From there just change your varibles as you please
If it was 5:1 inside the case youd be spinning 11000 @ 60mph...
n0 acc0rding t0 my tiny tach, my p01ini is r0ckin 12k d0wn a big 10ng hi11! yay! I can't wait t0 get my gi1ard0ni ready, I'm takin it rea11y s10w with that beast
hey crack, is it 5:1? or is that just an example?
E50 of course
I don't have a PC so I can't run Jaap calculator, can someone run it and check the speed with:___ Polease!
11000 RPM with 15
sorry it wasn't 12k it was 11200 I missread the tiny tach, since it cuts 0ff the 1ast digit 0nce y0u pass 10000 is sh0ws 0000 then 11000 is 1000 and a mist00k 1200 f0r 12000 dang, maybe 0ne day I'11 reach 12k, but I sti11 wanna knw h0w fast I was g0ing
Стев Браун /
Yo Hips,
At 11,200, you were doing 92.64 km/h aka 57.56 mph.
yay! thanks!
dang if I was g0ing 12k it w0ud've been 61.67 mph right? vr00m I wanna dd0 that indeed
Стев Браун /
Correct.
12k is where the party's at.
i think XmopedracerX mentioned it was 5.05:1 or something in that other post brought up earlier. I dunno i just finally got my first E-50 and haven't counted teeth yet.
yummmmmmm.
still, how did you get 11,200 rpms with 15x36 gearing? that's insane!
big hi11, pantie h0se air fi1ter, c0nservitave1y p0rted, new whee1 bearings, and again it was a BIIIIGGGG hi11
and I'm natura1y aer0 dynamic
