murray puch
Hi
Stock except tech no pipe and bigger jet and hi flo air cleaner.
Bogs a little at mid range then you open it up and she jumps right up to 38 and wants to go faster you can tell.
What can I do to get it more smooth all the way from start to full throttle?
Bob
Re: murray puch
You might be able to adjust the needle valve on the slide to clean up that mid range some.
Re: murray puch
Thanks I will give it a try.
Cheapest moped of my 3 and runs the best and fastest.
Bob
Re: murray puch
what size jet? Its pipe less? I got a murray i tyring to get it alittle faster.
Re: murray puch
Brendan Chenelle /
you can raise and lower the needle on the slider to help with part throttle mixture. It has several notches in it.
