Re: Peugeot 103 polini bottom end install problems
Michael Mike /
You can kinda make it fit.. you need to do a little cutting on the swingarm. Just bust out the old dremel and cut the forward section of the cross piece out. I also cut down the spigot piece of the carb a little and that will help as well. You want try and get the carb as close as you can to the motor. I also hacked off the vacuum piece on the one side of the carb and epoxy over that to help make some room. Anyways, lots of work...
-naz
