Peugeot 103 polini bottom end install problems
Zachary Evans /
Whee... this has me confused.
I got the polini bottom end, 50cc kit, 19mm dellorto race carb, and simonini pipe.
I've done all the busy work, and was getting around to mounting it today.
However, the carb hits the frame (yay variators). I flipped the intake around a couple times, and I can't find a way that keeps it from hitting something (either it's the float bowl on the swingarm, or the top of the carb bashes the frame.
Getting a larger belt doesn't appear to have any way of helping it either, there's just not enough room in there.
I know some of you run this setup, so maybe you could enlighten me to what made it work for you.
Pic to come.
And is it just that I'm using the race eddition? I don't have a normal one to compare it to at present.
~Zack
