Puch with A35
Okay, i don't know how awful of an idea this is, but will an A35 cylinder fit on like a puch za50 or e50? just thought it might be a little better, being new and reedvalve...
Re: Puch with A35
yep yep
some fast ass a35 cylinder puchs out there.
Re: Puch with A35
good, that's what i thought. sorta like using the korado cylinder, new=better?
Re: Puch with A35
ooh dude, you're from the cranks, did you meet Salty?
Re: Puch with A35
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
i met salty in kzoo last year, he's rad
Re: Puch with A35
he defnitly is.
Re: Puch with A35
can and has been done. Is known to rip. Ours did 50 on a decline. 40+ on flats. Super rad!
Re: Puch with A35
is it like bolt on... or is there case matching.. or is it even difficult at all?
Re: Puch with A35
there are some mods that must be done: intake, adapting the studs (tomos uses studs 1 or 2 mm bigger), lining everything up, and making an exhaust work with the angled exhaust port.
So its not exactly bolt on, but its easier than installing an 80cc kit.
For maximum potential it will be case matched, ported and some other stuff done.
Re: Puch with A35
🇮🇹💦 Of the Loin /
a35 matches up to e50 case. ive got one right here!
also i just slid it on, i didnt need to adapt the studs.
angled exhaust and intake are what needs to be done
Re: Puch with A35
niice, thank you everybody
Re: Puch with A35
I might add that the 35 cylinder isn't so hot w/o some porting on exhaust and transfer ports.
Re: Puch with A35
no problemo, i'm gonna practice that on some PA50 cylinders
Re: Puch with A35
wait what needs to be done to the intake? the whole point of the mod is that the a35 has a reed valve intake, right? do you get to keep it?
Re: Puch with A35
It's just that the cylinder becomes horizontal on the puch and the tomos intake won't relate. I made one out of copper plumbing fittings soldered with the non lead solder cause it's a little tougher than lead solder. The reeds stay
Re: Puch with A35
i want to try a 70cc airsal on my e50 bet that would scream
Puch with A35
Ed, bring it out for the fix/ride and we will get you fixed up.
Re: Puch with A35
hah salty, i want to buy that green puch from you, that's why i was asking. My friend bailed, so i want it now.
