with the stock gears in the rear wheel, high 50mph tops
i've heard the kinetic cdi doesn't like to idle very well, but was ok otherwise.
also, i am confused by your parts list, did you get the whole crank case? or just the intake half? because you'll need the whole crank case, as the simo 90 uses 4 head bolts rather than 3
