Vespa Si with Simonini kit 90cc, cdi ?'s
I just ordered the simonini kit for my bike (new cylinder, head piston 90cc's, the case inducted reed valve and a 21mm carb. Also I got the Simo Pipe. It's huge. I recently bought a used kinetic engine that I plan on using in case the motor seizes. It has a cdi too. So, I want to know what kind of lights should I use to replace my current bulbs. The cdi setup is 12v verse my current 6v setup. My bro says I'll need to get a voltage regulator as well. Do I need a "performance cdi?" or will the stock kinetic work fine... My tail lamps use a 4w and 6w bulb. What should I use withe the 12v cdi setup. I appreciate and all feedback.
Andy
Re: Vespa Si with Simonini kit 90cc, cdi ?'s
jesusssss. thats a huge kit.
70+ mph?
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
with the stock gears in the rear wheel, high 50mph tops
i've heard the kinetic cdi doesn't like to idle very well, but was ok otherwise.
also, i am confused by your parts list, did you get the whole crank case? or just the intake half? because you'll need the whole crank case, as the simo 90 uses 4 head bolts rather than 3
Oh... well I just got the thing and it uses 3... it is a simo...90? Did yo mean that the Kinetic engine has 4? I haven't pulled it apart yet, but I am fairly sure it is also 3...
kinetic`s all have 3
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
hmm, i must be thinking of a different simo vespa kit. nevermind!
Why would "the motor sieze"? If anything, the cylinder is what's going to sieze and having a spare motor aint gonna help you.
that thing is not 90ccs looks like 75 tops!!!
what is the diameter of that cylinder?
i bought it from treats. 90cc simo kit.
