no that doesn't make any sense at all. there are two kinds of chokes: chokes that limit air intake, and chokes that increase gas intake. in other words, by putting on your choke, you are making the mixture richer. you do this when starting the bike (sometimes) because the gasoline doesn't burn as efficiently when the motor is cold, so you need a little more of it to get started. but you don't have to . . . you can always just not have the choke on . . . there's no reason to remove it.
it is important with some carbs, like the encarwi found on batavus bikes, to make sure that when the choke is off, it's all the way off. sometimes the cable is a little too short, leading to a condition where the choke is always partly on, hence slightly less air can get through than would optimally.
