Re: Batavus Performance
jack /
Was that sinsire? or sarcasm lol either way i dont care
ALL MODS LISTED BELOW ARE ON YOUR OWN WILL AND I DO NOT TAKE RESPONSIBILITY FOR YOU FUCKING UP
get the 15mm intake and carb, bolt it up
milling the head can be done by your self at home carefully, you go to a store and get a fake piece of marble, then get some sand paper of grits you find appropriate to sand down a head, then tape down the sandpaper to the marble and rub the head in a figure 8 on the sandpaper, being careful not to tip it one way or another, this takes time but is worth it as you get a perfect seal as long as you do it to the cylinder as well then finish up with some more fine sandpaper mill it down as much as you see fit but if you go too far and the piston hits the spark plug, then just add a really thin gasket to make it not hit but make sure theres adequate room for expansion of the metals, if you mill it down this far i strongly recommend the super gas at the gas station if not racing gas because it is high compression
i have heard adding base gaskets will improve speed as it does give the engine a longer exhaust port duration that changes the power curve but i have not done it so yeah
the reed is modifiable, you grind out the studs holding the reeds on and then after they are removed, file the area down flat, then grind out the thing in the middle of the two air flow passages, and get some Boysen reeds or what ever reeds you chose and tap some new holes in the reed and then screw on your new reeds allowing at least!!!!!! 1mm overlap on every side where the reed contacts the cage
i would strongly advise against the Biturbo because the specs are way out of proportion to this bike, but if you want simplicity, then go this way otherwise get any other pipe from a Puch or Tomos and make it fit with a little cutting and welding
the exhaust port in the cylinder is very restrictive and i would get rid of the "steps" in the port
match the cylinder to the case
get new rings if you are getting a lot of blow by and the wrist pin as this is probably worn as well maybe even a new piston
if the piston at BDC does not uncover the exhaust port all the way grind out the piston on that side until it does
if you want to get advanced, then email me but it does require extensive modification
PS
should i post this in the wiki?
