What you need there Fred is a 2.15 needle jet. That will fix your idle problem. I believe the carb comes with a 2.17 needle jet. The 2.15 is the smallest I've seen for a Bing with a 4 position needle. It will lean out your idle and will make you have to readjust your needle settings for mid throttle. I'd call around and see if anyone has it.
