How can I get my guzzi robin to go faster than 23/24mph? The engine is the same as on some benellis.
Bore the intake, I think it's a 12mm on there now. Upgrade the carb, I think it has a 14/12 now. Rig up an expansion chamber exhaust. Make sure you have good compression, if not check the rings, PW50 rings will work a replacement.
I had one, it did 30 stock, just took a while to get there.
I'll try that, thanks.
