Any idea where I can find an exhaust flange in So Cal? I want to fab some custom intakes - just need the flange.
if your gunna custom fab stuff, then make your own. its not hard with a drill press and a bandsaw
true that fab is fab DO IT ALL
Thanks for the lesson. I can potentially make these very quick and cheap due to resources I have available to me. If they come out well, the low cost would potentially be to everyone's advantage. My point - making the flange is too time consuming if there is something readily available.
And its not sooooo
I will only make 1 or 2 if i can't find anything.
Great big washers for a 1 inch bolt or pipe is what I use . Home Depot has them in the construction area . Also an oil pick-up tube from a V8 works too .
That's what I was just thinking
