where are all the clutch spring reviews?
how is the performance?
how is clutch wear?
how many turns in 1.5 or 2 ?
does it feel like a two speed?
thanks
how is clutch wear?
thanks
Review: These springs are awesome.
I don't know that it feels like a 2 speed on mine, but it revs up and grabs and goes. My polini had good low end with a simonini and these, so I guess that says a lot.
Clutch wear is a bit more pronounced, but mine is fine after several hundred miles.
I forget how many turns I did. I messed with it a lot.
Don;t forget to change you transmission fluid more often. As the clutch wears, you fluid gets gross and should be changed. Also, careful with the heat. I've seen some blown clutch drums and heard some scary stories.
