Hello,
So, I read all I could in the 2stroke tuner's handbook about ignition advance, which wasn't much, really, and all it said was to try different degrees btdc to find the optimum ignition point.
Well, I'm happy to do that, but I thought maybe someone had any input about how far they advance their timing??
I know stock is .8-1.2mm btdc, so when I had it set at that, the performance was really bad. Now it's set at 2mm, and the mid-range is really good, but the top end is not so great.
Sooo, how far are you guys advancing your timing?
My setup:
Portmatched 64cc puch polini kit (stock reed valve)
15 bing
bullet pipe
Yup, thanks:) !!
Willie.
