I have a Puch Maxi that I got running and it runs pretty smoothly with the exception of the hills....which in Athens, GA are in great abundance. I have a 12mm Bing with 70 jet, proma GP exhaust, petcock, fuel filter, high flow Puch air filter, 49/50cc (I am not sure which one exactly)stock cylinder and piston, and I can't seem to find 1/4 fuel line so right now I went down from 1/2" to 1/8" and it runs better but I think I need to find that 1/4". The moped runs great up slight hills and can even accelerate but when it comes to the big hills it slows down anywhere from 16/18-8mph, depending on the grade of hill. I would like to stay within the GA Law and keep the thing street legal by not going over 50cc, b/c I would rather not go over that just for the time being. My question is whether it would be beneficial to change my cylinder to the 50cc TCCD cylinder and piston with the set up I have now and would it make that much of a difference? (I will change the fuel line out to 1/4" when I get the chance to find some, b/c that is what size the petcock appears to be as well as the same size as the carb) I would rather not spend a whole lot more money into it, but if you would think it worth the money I would probably switch. I am not entirely sure of my gear ratio but it is stock to my knowledge...I just have never changed it out. I will try to post a pic sometime. And thanks for your advice in advance. The moped is just used to drive about 6 miles to work/classes and back.
-william
