Thank you for the help, I'll go check it out. I'll change the filter too, it needs to be done.
It's a QT50 with a YT60 cylinder bored out to take a 70cc piston. Biturbo exhaust, YT60 head, boysen reeds, ported as much of the intake manifold as much as I could reach, and the VM18 which is gorgeous.
Vm18 took a while to set up, and I still haven't adjusted the throttle cable enough to open the throttle fully. If anyone is trying to do the VM18 on a Yamaha QT I have some tips for ghetto rigging it:
1) If you can't get a delrin spacer made (my local machine and bike shops couldn't do it), uses your stock spacer and space it out using strips of aluminum between the intake manifold body and the spacer. Works great.
2) Making the right length throttle cable is easy. There is a 2 to 1 throttle divider that runs to the stock carb and to the oil injector. take both cables off and use the oil injector cable in reverse as your throttle cable. This is nice because the oil injector cable has an adjuster on it. I have mine adjusted all the way out. Also, keep the cable on the oil injector spot in the 2-1 divider, this position gives more throttle pull.
3) I'm working on making the choke adjustable from the handle bars, it looks do-able.
