Re: Converting step through to top tank
Crazy Hakachukai /
I'm not familiar with that model, but I've noticed on the Targa LX vs the Sprint that the two main differenaces seems to be:
The top tank model has mounting tabs welded on that the tank pivots on.
The step through model uses the front part of the chassis as a gas tank, and therefore has a gas cap on the chassis.
The problem is, that if you want to weld the mounting tabs on... you'd be welding RIGHT on the side of what they were using as a gas tank. Needless to say, if your going to do that you better fill the tank with a noncombustable liquid first. (prefferably one that won't hurt anything else either.
I'm not sure if the seat is different or not. But you migth have to add the little gas tank mounting bracket thing.
  Converting step through to top tankTopic by: Adam Adam 04/06/08 05:17AM
  Converting step through to top tankRe: Brennan O. Brennan O. 04/06/08 11:30AM
  Re: Converting step through to top tankRe: coco coco 04/06/08 12:23PM
  Re: Converting step through to top tankRe: Eric P Eric P 04/06/08 02:37PM
  Re: Converting step through to top tankRe: Brian Blazel Brian Blazel 04/06/08 03:21PM
  Re: Converting step through to top tankRe: Adam Adam 04/10/08 02:14AM
  Re: Converting step through to top tankRe: Brennan O. Brennan O. 04/10/08 02:18AM
  Re: Converting step through to top tankRe: ; . ; . 04/10/08 03:17AM
  Re: Converting step through to top tankRe: Adam Adam 04/10/08 05:13AM
  Re: Converting step through to top tankRe: Crazy Hakachukai Crazy Hakachukai 04/10/08 04:13AM
  Re: Converting step through to top tankRe: coco coco 04/10/08 10:08AM
  Re: Converting step through to top tankRe: bobsled bobsled 04/10/08 11:57AM
  Re: Converting step through to top tankRe: derek derek 04/10/08 11:57AM
  Re: Converting step through to top tankRe: David Ciao David Ciao 04/11/08 01:35PM
  Re: Converting step through to top tankRe: Adam Adam 04/11/08 11:42PM
  Re: Converting step through to top tankRe: coco coco 04/11/08 05:35PM
  Re: Converting step through to top tankRe: Adam Adam 04/11/08 11:46PM
  Re: Converting step through to top tankRe: .Allen Schlung .Allen Schlung 04/11/08 07:43PM
  Re: Converting step through to top tankRe: Sara K Sara K 04/11/08 10:30PM
  Re: Converting step through to top tankRe: Adam Adam 04/11/08 11:53PM
  Re: Converting step through to top tankRe: Knarpsworth - Knarpsworth - 04/11/08 11:00PM
  Re: Converting step through to top tankRe: Sara K Sara K 04/11/08 11:08PM
  Re: Converting step through to top tankRe: Brennan O. Brennan O. 04/11/08 11:12PM
