Re: New Polini bottom end for Peugeot 103
siestaport /
Yeah I have been running one. It's a really good case, made very well (as opposed to other polini products). Comes with an intake for a dellorto 15mm and for a 19/21mm. There are a lot of good cranks available -- if you get a polini bottom end then you should also get a good crank to go with it.
The polini bottom end will be better than modifying a stock case. Modifying a stock case is a lot of work because in grinding out a third port you hit some air pockets that need to be filled in with metal, plus the stock intake on the case sucks, the polini setup is bigger and has better flow.
Malossi also makes a case, I am getting one any day now and will be using that instead. I will most likely keep my polini case though.
The pedal thing you're talking about is not necessary, I've never used it so I can't say for sure, but apparently it causes a lot of friction and is basically something you would use in lieu of a polini or doppler tension spring. Basically, the stock tension spring isn't tough enough so the engine variates too quickly, and you can solve this problem by putting a tougher engine spring on (preferred option) or getting one of those pedals and manually forcing the engine forward.
  New Polini bottom end for Peugeot 103Topic by: Zachary Evans Zachary Evans 04/04/08 12:14PM
  Re: New Polini bottom end for Peugeot 103Re: lee's anus is leefungchowOG lee's anus is leefungchowOG 04/04/08 02:28PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/04/08 02:56PM
  Re: New Polini bottom end for Peugeot 103Re: elliot elliot 04/04/08 03:13PM
  Re: New Polini bottom end for Peugeot 103Re: derek derek 04/04/08 03:46PM
  Re: New Polini bottom end for Peugeot 103Re: Casey Griffin Casey Griffin 04/04/08 04:33PM
  Re: New Polini bottom end for Peugeot 103Re: naz naz 04/05/08 04:01AM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/04/08 06:04PM
  Re: New Polini bottom end for Peugeot 103Re: Zachary Evans Zachary Evans 04/05/08 12:42PM
  Re: New Polini bottom end for Peugeot 103Re: elliot elliot 04/05/08 02:23PM
  Re: New Polini bottom end for Peugeot 103Re: Michael Mike Michael Mike 04/07/08 02:07PM
  Re: New Polini bottom end for Peugeot 103Re: lee's anus is leefungchowOG lee's anus is leefungchowOG 04/07/08 02:22AM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 01:30PM
  Re: New Polini bottom end for Peugeot 103Re: Eric Sabatino Eric Sabatino 04/07/08 01:43PM
  Re: New Polini bottom end for Peugeot 103Re: Michael Mike Michael Mike 04/07/08 02:03PM
  Re: New Polini bottom end for Peugeot 103Re: Michael Mike Michael Mike 04/07/08 02:10PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 02:10PM
  Re: New Polini bottom end for Peugeot 103Re: Zachary Evans Zachary Evans 04/07/08 02:31PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 02:58PM
  Re: New Polini bottom end for Peugeot 103Re: Zachary Evans Zachary Evans 04/07/08 03:09PM
  Re: New Polini bottom end for Peugeot 103Re: Michael Mike Michael Mike 04/07/08 05:40PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 03:34PM
  Re: New Polini bottom end for Peugeot 103Re: Zachary Evans Zachary Evans 04/07/08 03:38PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 03:43PM
  Re: New Polini bottom end for Peugeot 103Re: Zachary Evans Zachary Evans 04/07/08 03:46PM
  Re: New Polini bottom end for Peugeot 103Re: siestaport siestaport 04/07/08 03:55PM
  Re: New Polini bottom end for Peugeot 103Re: Michael Mike Michael Mike 04/07/08 09:08PM
