i just bought a biturbo for my print just wondering if someone could help me out???
i just bought my sprint and it needs more power
help you with what? you've got the pipe, put it on and upjet.
this is needed FYI
unbolt the old one dude, and bolt the new one on...c'mon this isn't rocket science
Here it is 10mm bolt, get your ratchet and socket, Make sure it's a long reach, get on your back, go to the top of the header and start turning the ratchet left.
Make sure the ratchet isn't clicking, if it is than turn the dial.
There is another Bolt in about the middle. Take it off.
Than bolt the new one on.
Easy.
Adding on to the above post, make sure the flange on the cylinder is clean, and use a new gasket.
now, i am thinking of getting a sprint and going with the biturbo exhaust....when rejetting, is it as simple as changing the brass jet, or is there more to it? also, what would the recommended jet be for a stock sprint carb w/ biturbo exhaust?
Hehe.. c'mon guys, if it was anything but a Tomos you'd only give him half as much shit.
