Putting together my new Metrakit 65cc.
What jetting are people running for this setup. Or close.
E50
Case matched MK 65cc
15mm intake
15mm bing.
High flow filter.
Bullet pipe.
Stock gearing.
What jets should I start with.
E50
15mm intake
15mm bing.
High flow filter.
Bullet pipe.
Stock gearing.
start hi, and work backwards
still cold in michigan so maybe bigger stuff... 86?
i ran a similar setup last year in the summer and i think i had a 74 in there
so should I start with the stock bing 82 and work down.
Of higher?
starting at 86 is what i do, then go down til it aint all super dark tar colored. then blammo you're good to go
i would get a range of 78 - 90
I've heard the stock 15 Bing jet is good or at least a good place to start.
