Can anyone point me in the direction of a supplier of a liquid cooled 70cc kit for the PA50?? 50cc.nl no longer stock this item.
Mopshop.de has em. They don't come cheap tho.
The kit
Waterpump
I bet benji would be able to get one for you. check ebay under treatsHQ
now whats the water pump run off of i see the pulley and the mini tiny belt but whats it drive off
wheres the radiator
Treats says he can't get hobbit watter cooled kits any more
"Last Question":http://stores.ebay.com/treats-hq-discount-puch-moped-parts/myths-facts-sordid-truths-n-such.html
Typically, the water pump runs off a custom 'long' nut fitting on the stator. You remove the stock one and replace it with the custom one. It has a long end to which comes out far enough with a grove on it. The pump has to mount inline with it obviously and the little belt is nothing more than an o-ring gasket on steriods.
And yeah....those links had everything you need, cylinder, piston, head, hoses, pump.....NO RADIATOR. Need that otherwise you might as well not even put the rest on.
i guess just about anything can be used for a radiator like a heater core from a car or a radiator on a small liquid cooled dirt bike or maybe even a piece of baseboard forced hot water heater pipe
Yeah, or you can use an actual radiator designed to get rid of engine heat.
Try one from a cheap chinese scooter. They are readily available everywhere and don't cost a thing.
seriously. also the small KTM dirtbikes are hydro. like the KTM65 series.
Thanks for the info guys, kit now on order.
Have a radiator from a modern 50cc lc scooter from the local scrap yard to go with it.
I'll add to this post when the parts arrive.
