Just bought a 77 sparta foxi, runs great, but Im hoping to get a bit more out of it. What are some upgrades/adjustments I should be thinking about?
Can you let us know what setup it is?
Does it have 40hph on the cylinder ? Does the carb say 10 or 12 on the side in the middle number? Does it have a torpedo shaped exhaust tapered at the end or a blunt one?
high flow filter, bigger carb, exhaust, port work that should do it
well the reason i asked was if its the 504/b and you do all that stuff jack mentioned you will need a clutch too.
they're no good. part it out and send me the side covers, front fender, front brake assembly and kick stand.
