Carburetor: 12mm Dellorto, no needle, just has a slide.
When the bike is not running, there is fuel leaking from a hole underneath the bore, where the air filter attaches. I have checked the float level and it's fine, the float needle is in good state. The only possible problem, although it is all standard, is that the carburetor leans forwards ever so slightly (at about 10
