I've run into the problem, of these wrist pin bearings being too short, ie there is too much slop (5mm) worth between the bearing and the piston, what did you guys do about this, or where you even aware of it, are you worried? Lets all come up with a solution, maybe if I find some wider needle bearings I can order like 5 or 6 so we all can get them, maybe even save $
