Re: a35, can't achieve higher rpms
Ja'Far Rogers /
Did you also lower the intake port? You shouldn't raise an exhaust port by such a degree unless you intend on also lowering your intake port, remember that timing is everything. Also, raising CR's tends to limit rpm, you want lower than stock CR's for higher rpm's.
  a35, can't achieve higher rpmsTopic by: dallas dallas 02/26/08 09:00PM
  Re: a35, can't achieve higher rpmsRe: MLM Devin MLM Devin 02/26/08 09:18PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 09:19PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/26/08 09:50PM
  Re: a35, can't achieve higher rpmsRe: elliot elliot 02/26/08 10:00PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 11:07PM
  Re: a35, can't achieve higher rpmsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/26/08 11:21PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 11:26PM
  Re: a35, can't achieve higher rpmsRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 02/26/08 11:32PM
  Re: a35, can't achieve higher rpmsRe: MLM Devin MLM Devin 02/27/08 10:14AM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/27/08 12:45PM
  Re: a35, can't achieve higher rpmsRe: coco coco 02/27/08 01:54PM
  Re: a35, can't achieve higher rpmsRe: Austin Austin 02/27/08 02:38PM
  Re: a35, can't achieve higher rpmsRe: Graham Motzing Graham Motzing 02/27/08 02:41PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 04:43PM
  Re: a35, can't achieve higher rpmsRe: scott scott 02/27/08 06:03PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 06:27PM
  Re: a35, can't achieve higher rpmsRe: Zack Bandit Zack Bandit 02/27/08 07:47PM
  Re: a35, can't achieve higher rpmsRe: Casey Griffin Casey Griffin 02/27/08 08:24PM
  Re: a35, can't achieve higher rpmsRe: scott scott 02/28/08 01:30AM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 10:54PM
  Re: a35, can't achieve higher rpmsRe: Responsible Jon Responsible Jon 02/28/08 02:54AM
