a35, can't achieve higher rpms
dallas /
technigas, 16mm intake and carb, 27 front tooth, milled head, ported cylinder and case.
so the exhaust port is raised 3mm's from stock. I'm going a solid 39, with crazy low end.
so we got an extra cylinder to experiment with, opened up all of the ports a little wider than what I have on original cylinder, and raised the exhaust port 7mm from stock.
same results.
same rpms as before. is anyone breaking 40 on a stock cylinder? maybe need a higher rpm pipe? let's talk shall we?
  a35, can't achieve higher rpmsTopic by: dallas dallas 02/26/08 09:00PM
  Re: a35, can't achieve higher rpmsRe: MLM Devin MLM Devin 02/26/08 09:18PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 09:19PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/26/08 09:50PM
  Re: a35, can't achieve higher rpmsRe: elliot elliot 02/26/08 10:00PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 11:07PM
  Re: a35, can't achieve higher rpmsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/26/08 11:21PM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/26/08 11:26PM
  Re: a35, can't achieve higher rpmsRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 02/26/08 11:32PM
  Re: a35, can't achieve higher rpmsRe: MLM Devin MLM Devin 02/27/08 10:14AM
  Re: a35, can't achieve higher rpmsRe: Ja'Far Rogers Ja'Far Rogers 02/27/08 12:45PM
  Re: a35, can't achieve higher rpmsRe: coco coco 02/27/08 01:54PM
  Re: a35, can't achieve higher rpmsRe: Austin Austin 02/27/08 02:38PM
  Re: a35, can't achieve higher rpmsRe: Graham Motzing Graham Motzing 02/27/08 02:41PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 04:43PM
  Re: a35, can't achieve higher rpmsRe: scott scott 02/27/08 06:03PM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 06:27PM
  Re: a35, can't achieve higher rpmsRe: Zack Bandit Zack Bandit 02/27/08 07:47PM
  Re: a35, can't achieve higher rpmsRe: Casey Griffin Casey Griffin 02/27/08 08:24PM
  Re: a35, can't achieve higher rpmsRe: scott scott 02/28/08 01:30AM
  Re: a35, can't achieve higher rpmsRe: dallas dallas 02/27/08 10:54PM
  Re: a35, can't achieve higher rpmsRe: Responsible Jon Responsible Jon 02/28/08 02:54AM
