Plus, then you'd probably have to remove the fan/flywheel cover to let air flow over the cylinder fins. That would leave the flywheel exposed to dirt, water, etc. Plus it would look ugly. I suppose you could modify the cover, but then your cover is ruined if you ever want to put the fan back on.
