Converting vespa ciao to 12v
I got a lead on some kinetic parts. Just wondering what exactly do i need.
Re: Converting vespa ciao to 12v
no help?
Stronger rotor magnets? Bigger lighting coils?
What are you trying to accomplish, exactly?
I mean, you could just swap out the flywheel and the coils and the HT coil and the bulbs and stuff from the kinetic to the ciao, but why would you?
Are kinetics electronic ignition?
Mike, get the flywheel, HT coil, ignition coil, lighting coil, voltage reg, and CDI box
Brad nailed it.
They have an ignition but it's more of an one of switch.
Why would you want to convert to 12v, and how is this performance related? Am I missing something?
It's CDI, that's the draw. Plus you can run 12 lights which open up more options
Standard 12 volt LED tailights without modification. Just pop em in the socket. I wish I had the resources to do 12v
