Re: Hydroforming Expansion Chambers
Count Hippula /
i've personally done this and it is not unsafe.. well as far as i have done it... i even added heat externally with a torch to pop out some kinks. the only hard part was making clean strong welds... i acchived this two different ways first by tourch welding the two pieces together without any rod, just overlaping the 22guadge sheet metal and evenly melting them together, then when i put it on and found leaks i just added rod and patched as flat as I could because thick welds led to uneven expanding... the next one I made was useing a MIG with the wire speed turned way down so I could make deep flat welds.. then patched with the tourch like before... works great, and all in one afternoon. woo
  Hydroforming Expansion ChambersTopic by: Responsible Jon Responsible Jon 02/15/08 01:37AM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/15/08 01:41AM
  Re: Hydroforming Expansion ChambersRe: GRINDER GRINDER 02/15/08 04:03AM
  Re: Hydroforming Expansion ChambersRe: SchijnHeilig SchijnHeilig 02/15/08 08:49AM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 10:44AM
  Re: Hydroforming Expansion ChambersRe: Bruce Edwards Bruce Edwards 02/15/08 11:10AM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 11:45AM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 11:52AM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 12:01PM
  Re: Hydroforming Expansion ChambersRe: warisesi warisesi 02/15/08 12:08PM
  Re: Hydroforming Expansion ChambersRe: Carl M Carl M 02/15/08 12:23PM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 01:59PM
  Re: Hydroforming Expansion ChambersRe: warisesi warisesi 02/15/08 12:30PM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 12:57PM
  Re: Hydroforming Expansion ChambersRe: Lyntoft Lyntoft 02/15/08 02:45PM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/15/08 02:51PM
  Re: Hydroforming Expansion ChambersRe: Count Hippula Count Hippula 02/15/08 03:21PM
  Re: Hydroforming Expansion ChambersRe: Count Hippula Count Hippula 02/15/08 03:22PM
  Re: Hydroforming Expansion ChambersRe: tikiman.. x3 tikiman.. x3 02/16/08 06:27AM
  Re: Hydroforming Expansion ChambersRe: foxboss9 foxboss9 02/16/08 10:42AM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/16/08 01:07PM
  Re: Hydroforming Expansion ChambersRe: Graham Motzing Graham Motzing 02/17/08 01:59PM
  Re: Hydroforming Expansion ChambersRe: Brent Brent 02/17/08 03:22PM
