Re: Hydroforming Expansion Chambers
Carl M /
As mcgregor mentioned, you can't compress water like you can compress air.
If air is pressurized in a container, it compresses. When the container breaks, the air decompresses rapidly, releasing a bunch of energy (like the sound of a balloon popping). That energy also sends stuff flying, and that's what hurts you.
When water is pressurized in a container, it just pushes out on the walls without storing the energy itself. When the walls break, they still can go flying from the force that the water was pushing on them, but the water doesn't add to the mix by rapidly releasing energy to give the walls an extra boost.
Take two empty soda bottles. Fill one with water and leave the other empty. Make sure both caps are on tight, and run over both of them with your car. See which one has the more violent failure.
  Hydroforming Expansion ChambersTopic by: Responsible Jon Responsible Jon 02/15/08 01:37AM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/15/08 01:41AM
  Re: Hydroforming Expansion ChambersRe: GRINDER GRINDER 02/15/08 04:03AM
  Re: Hydroforming Expansion ChambersRe: SchijnHeilig SchijnHeilig 02/15/08 08:49AM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 10:44AM
  Re: Hydroforming Expansion ChambersRe: Bruce Edwards Bruce Edwards 02/15/08 11:10AM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 11:45AM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 11:52AM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 12:01PM
  Re: Hydroforming Expansion ChambersRe: warisesi warisesi 02/15/08 12:08PM
  Re: Hydroforming Expansion ChambersRe: Carl M Carl M 02/15/08 12:23PM
  Re: Hydroforming Expansion ChambersRe: Crackstar X Crackstar X 02/15/08 01:59PM
  Re: Hydroforming Expansion ChambersRe: warisesi warisesi 02/15/08 12:30PM
  Re: Hydroforming Expansion ChambersRe: mcgregor mcgregor 02/15/08 12:57PM
  Re: Hydroforming Expansion ChambersRe: Lyntoft Lyntoft 02/15/08 02:45PM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/15/08 02:51PM
  Re: Hydroforming Expansion ChambersRe: Count Hippula Count Hippula 02/15/08 03:21PM
  Re: Hydroforming Expansion ChambersRe: Count Hippula Count Hippula 02/15/08 03:22PM
  Re: Hydroforming Expansion ChambersRe: tikiman.. x3 tikiman.. x3 02/16/08 06:27AM
  Re: Hydroforming Expansion ChambersRe: foxboss9 foxboss9 02/16/08 10:42AM
  Re: Hydroforming Expansion ChambersRe: Austin Austin 02/16/08 01:07PM
  Re: Hydroforming Expansion ChambersRe: Graham Motzing Graham Motzing 02/17/08 01:59PM
  Re: Hydroforming Expansion ChambersRe: Brent Brent 02/17/08 03:22PM
