Re: Moby CDI on AV7 - how?
Mike Alanko /
elliot are you running points then? or are you with Peter in the avance variable realm?
got a hex novi-esque nut that seems to line up nicely, not worried there.
looks like i need a washer behind each bolt as the plate is hitting the end of the case ever so slightly - 1.5mm slightly.
backwards?!? awesome.
this is why this is my spare motor :)
