Re: Jetting for my ciao? suggestions
maciek /
depending on how much you port and what all that junk means, if not then you should end up somewheres around 60 or smaller..I'd start with the 66 that comes with the 13.13 and some jets in the fifties and low sixties to downjet through untill it stops four-stroking, that is if you are not splitting the case to do any case and crank work, open up the intake, etc..
