Re: amal carb on puch help
Tracy (a dude) /
thanks a ton brent, I went out there and figured it out. The needle was in its lowest position, and I moved it up a notch. It totally helped the problem! I still bog very slightly, so im trying to figure out if i can adjust the air mix precisely to fix it, or maybe ill try bringing it up another notch. Thanks so much!
