Does 49mph with a 64cc Airsal, a 16mm Dellorto, and a Homoet 4p sound about right to you guys?
whats the gps say and has there been port workk done
Sounds about right.
what gears?
Stock gearing, head decked forgot about that! No port work was done to it. Speed was recorded by my friend Ian riding behind me on his 2006 Bandit 1250
Optimistic. Check with a GPS
Yeah, give or take 2 or 3MPH that should be it.
Port it and try a 18 or 20mm PHBG for some more speed. (Maybe 5 to 8MPH if you're lucky :))
You can also change the gearing to slightly heavier gears. Will cost you some low end, but gives you a few miles more on top speed.
That as fast as I want to go. Would like to crack 50 though
First you'll want to crack 50, then 55. It never ends :)
Chas
