ebay item # 280196725111
Yes, depending on the kind of moped.
Will work for mopeds with a VDO speedo-drive. Can be identified by the markings "VDO" on the drive :P
Nice speedo :)
The only problems are:
You will have to have a special drive cable made up that matches both the drive end and the speedo end connections.
You need to know the rotation of the cable at the speedo end to be sure everything is compatible
Also the ratio of the drive gear can be different depending on the diameter of the wheel.
Lots of questions.....
