how bad is this much play? (video)
homoped /
so i lightened the main gear on this e50. took out 3 spokes with an angle grinder. i must have knicked the gear shaft while doing it though cause the sprocket has play now. this is going to be a kitted bike so im worried about stripping the gear shaft.
do i need to replace the main gear?
you think this is something that could be fixed with a little gentle welding?
i really dont want to have to crack this case again and modify a main gear again if i dont need to.
p.s. i dont want to weld the sprocket on if i dont have to. i would like to be able to play with the gearing.
