Spark plug for 70cc kit? Peugeot 103
Zack Rineer /
I am going home tomorrow to install all my new parts on the Peugeot 103 and do I need to get a different spark plug for the 70cc kit, or just use the one I have??
Also, I was told to run 4 oz. of oil per gallon of gasoline is this correct??
thanks,
zack
Re: Spark plug for 70cc kit? Peugeot 103
can you get one of those kits for a 102?
thanks!
I have never seen a kit that was specificaly built for a 102 but there might be something out there that has a close stroke that you could rig to fit but it is probably not worth the effort on a 102.
Zack Rineer /
yea, not sure if they have kits for a 102....
but i cannot wait for tomorow! hahaha
4oz is good
NGK b7hs plug
Zack Rineer /
thanks!! Now.. I have run into some issues...
I am putting the new piston on the connecting rod and do i use the stock little bearing thing? cause i tried getting the new piece through it and it broke.. but i do have a spare engine so im gonna get the bearing out of that...
also... with the new carb should i use all the stock gaskets and whatever else is there?? or what?
Zack Rineer /
nevermind.. selling everything..... broke the cylinder.........SHIT
how do you "break a cylinder"?
sounds like someone needs a steadier hand.
What did you do to the cylinder? Break a ring? pics would be helpful, considering you never fired it up you might be able to fix it. Or you could sell it to me.
Zack Rineer /
you dropped it didnt you
Daaaaaaaaaaaaaaaaaamn! Sorry man, That's such bad luck.
Keep sell the piston adn rings for 50 bux and put it twards your new 70 kit.
Oh, that's how.....yikes!
Zack Rineer /
yeah... bad luck id say.. shit sucks! im jsut selling everything cause i can't handle it.. lol
Dang.
What else are you selling, besides a busted kit?
In response to JenS: There aren't any kits for the 102. It's not really worth it on a 102, though. You can mildly port that cylinder and install a dellorto and get it going around 38 easily.
Zack Rineer /
erics, i am selling the dellorto 16 mm carb and intake, simonini performance exhaust....
i have it on the buy/sell forum
