Re: 64 METRA 20mm PHBG overkill?
Bort Hoff /
PHBGs and SHAs use the same jets. i doubt you'll have to fuck with the needles to much. The 20mm will not be to big. Measure the size of the piston port and compare that to the carb you want to use.
Also, be sure to remember that the metrakit ports are all twisted off-center for some reason.
  64 METRA 20mm PHBG overkill?Topic by: Count Hippula Count Hippula 01/18/08 04:45PM
  Re: 64 METRA 20mm PHBG overkill?Re: Brandi eat a treat Brandi eat a treat 01/18/08 04:54PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 04:59PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 05:00PM
  Re: 64 METRA 20mm PHBG overkill?Re: Bort Hoff Bort Hoff 01/18/08 05:16PM
  Re: 64 METRA 20mm PHBG overkill?Re: j j 01/18/08 06:22PM
  Re: 64 METRA 20mm PHBG overkill?Re: rafter rafter 01/18/08 05:18PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 05:27PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 05:30PM
  Re: 64 METRA 20mm PHBG overkill?Re: Colby Calkin Colby Calkin 01/18/08 06:32PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 06:37PM
  Re: 64 METRA 20mm PHBG overkill?Re: Graham Motzing Graham Motzing 01/18/08 06:52PM
  Re: 64 METRA 20mm PHBG overkill?Re: Colby Calkin Colby Calkin 01/18/08 06:54PM
  Re: 64 METRA 20mm PHBG overkill?Re: Count Hippula Count Hippula 01/18/08 06:57PM
  Re: 64 METRA 20mm PHBG overkill?Re: Colby Calkin Colby Calkin 01/18/08 07:03PM
  Re: 64 METRA 20mm PHBG overkill?Re: rafter rafter 01/18/08 09:13PM
  Re: 64 METRA 20mm PHBG overkill?Re: Austin Austin 01/18/08 09:15PM
  Re: 64 METRA 20mm PHBG overkill?Re: Austin Austin 01/18/08 09:18PM
  Re: 64 METRA 20mm PHBG overkill?Re: Colby Calkin Colby Calkin 01/18/08 09:22PM
  Re: 64 METRA 20mm PHBG overkill?Re: Austin Austin 01/18/08 09:30PM
  slightly ported not like birdsRe: rafter rafter 01/18/08 09:36PM
  Re: slightly ported not like birdsRe: rafter rafter 01/18/08 09:38PM
  Re: slightly ported not like birdsRe: Aris Dimalanta Aris Dimalanta 01/18/08 10:07PM
  Re: slightly ported not like birdsRe: Colby Calkin Colby Calkin 01/18/08 10:09PM
  Re: slightly ported not like birdsRe: Aris Dimalanta Aris Dimalanta 01/18/08 10:45PM
  Re: 64 METRA 20mm PHBG overkill?Re: elliot elliot 01/18/08 11:49PM
  Re: 64 METRA 20mm PHBG overkill?Re: elliot elliot 01/18/08 11:50PM
  Re: 64 METRA 20mm PHBG overkill?Re: Graham Motzing Graham Motzing 01/19/08 01:05AM
  Re: 64 METRA 20mm PHBG overkill?Re: Moped Game Sally Struthers Moped Game Sally Struthers 01/19/08 12:00PM
