i was wondering is the phgb 19mm carb had a 19mm inlet or outlet to the intake manifold. if its the size of outlet what size is the inlet? does anyone know?
it is 19mm on the intake manifold side
Most of the time the diameter of the carburetor is measured at the venturi.
well im having a velocity stack machined and im gonna use that carm. but i wanted to matxh it with the stack and intake manifold. the intake manifold is 19mm i need a carb to match
